DE 32 thoughts and suggestions
WaKen
Apr 18, 2025
1
Downeast 32 Oak Harbor
I'm new to Downeast boats but am looking at a 1975 32 for cruising the Sea of Cortez. I would appreciate any pros and cons, things to watch out for, etc. with this model.
I'll be single handing much of the time so suggestions about that will also be welcome.
Thanks
May 9, 2026
1
Downeast, O'Day, Catalina 32, 31, 27 Lake Arthur
Check the compression post, most are not good. replace it with one single post from ceiling to the keel. You will have to cut the corner of the shower pan to get it in there. save the parts of FRG to remake said corner.
Check the all important bulkhead where it is attached to the old post for rot replace as necessary being sure to epoxy the new materials together. If you cut it back overlay the repair with marine ply marrying the old to the new and again epoxy it together. If the deck has sagged you will see it in the door frame. Make the post long enough to push the deck back up where it should be.
Replace thru hulls with fiber reinforced plastic and replace the rotted wood backing too.
I have been rebuilding mine for years and know where some other improvements should be made. write to jameshandzus@outlook.com
  • Helpful
Regarding becoming a single hander, I would recommend you devour the resources of the SFBay Singlehander Organization.
Here is one of the PDF's they have put together.
SinglehandedTipsThirdEdition.pdf
Their archives are rich in helpful ideas for all boats that have single-sailor owners.
Success as a single-hander is about knowing your boat. Setting your boat up for ease of management. Planning for and acting before events occur.
Fair Winds.
