DC to DC charger size
But the Hitachi will sort of let you know if it’s getting too hot by how low its’ output voltage gets.
Here's why:
Hitachi/Yanmar Alternators: (by Maine Sail)
Some alternators though, such as those made by Hitachi and found on Yanmar diesels, are dumber than a pound of beetle poop. Actually, to the alternator, they are pretty smart but to your batteries and the speed of charging they are flat out stupid. Why?
Hitachi alts with dumb regulators, and some others, limit voltage but also reduce voltage based on alternator temperature. This is a self protective feature installed in the internal dumb regulator to prevent the alternator from cooking itself. Remember voltage is the pressure that allows more current to flow. So, if we reduce the absorption voltage, then we also reduce the current the alternator is supplying.. Any battery at any state of charge simply will not accept the same current at 13.4V that it did at 14.4V and as a result the alternator will run cooler. What do you suppose this does to your batteries over time.......?
The problem is that when cold you will get 14.3V to 14.4V out of the Hitachi but as the alternator heats up the dumb regulator begins to reduce the CV/voltage limit based on the alternators internal temperature. It is not uncommon to find a Hitachi alternator at 13.4V when hot. This is REALLY, REALLY DUMB....
If you have a dumb regulator, and notice the voltage dropping, it is likely a temp compensated dumb regulator. Get rid of it or plan to buy new batteries more often.
If you have a temp compensated alternator or a Hitachi alternator on a Yanmar you really are in dire need of external regulation if deep cycling a larger battery bank.
This is from:
http://forums.sbo.sailboatowners.com/showthread.php?t=125392
and these, too:
Hitachi Alternator and Smart Regulator Instal Question - Cruisers & Sailing Forums
Most practical way to upgrade Yanmar alternator? - Cruisers & Sailing Forums
All true, but if I remember right the guidance is generally from the era of lead batteries being charged either directly from alternators or through ACR’s. A lithium battery being charged by a DC-DC charger doesn’t care at all about the alternator’s output voltage. If the DC-DC is set to 40A and the alternator can push that much current in the low 13 volt range without overheating that’s fine for the batteries. You won’t get the charging as fast as a higher output better regulated alternator, but it won’t damage the lithium sitting longer at a low PSOC like lead.
Likes: Johann
Johann
Jun 3, 2004
585
Leopard 39 Pensacola
Here's why:
Yes those are great articles, and the Hitachi is a super dumb way to charge a lead house bank. But charging LFP through a smart DC-DC the Hitachi does a pretty good job. It will put out 40A all day and the DC-DC will make sure the LFP gets the right charging profile. If you wanted to push it higher (with the 50A XS) you could set an input voltage lockout so if the Hitachi dropped below say 13.5V the Orion would stop charging. Since the Hitachi output is also going to the start AGM there is no risk of a damaging voltage spike.
Likes: MFD
Johann
Jun 3, 2004
585
This advice worries me a bit. It doesn’t sound right. Doesn‘t the PS mode only output a single voltage? If so what voltage? If it’s above 13.6V that will damage your LFP over time.
I hate to quote myself to correct myself, but.... Just in case someone else with a Promariner charger and LFP is reading this... The PS mode doesn't supply a single voltage, it just keeps the charger from going to a California imposed energy saving mode that will cause your LFP to discharge to a low SOC. Here is a reference thread with information from RC. It is about Sterling but applies to Promariner as well.
Sterling 60A Charger Locking Up *HELP* | Sailboat Owners Forums
A couple of points. First and foremost, LFP batteries have a very low self-discharge rate, much lower than lead acid batteries. More importantly, LFP batteries do not do well when left in a 100% SOC, most LFPs should be store at between 50% and 70% SOC.
The ProMariner/Sterling chargers continue to monitor battery voltage in the CEC mode. If the battery voltage drops below a set point the charger will kick and start charging again. The charger will provide its full rated output until the voltage rises to the absorption voltage at which point it will reduce current until the acceptance level if very low, a couple of amps or so. (Sorry, can't remember the exact current.)
Johann
Jun 3, 2004
585
The point is to understand the PS mode and realize that it is not a constant voltage. The selected charge profile remains. The OP and many others leave refrigeration on and when they arrive at their boat they want the batteries to be ready at/near 100%, and accept the increased aging rate that holding 100% brings. Left in “bc” the charger will “Auto Maintain” and allow the LFP to discharge to 13.2V with a load on. This would be somewhere in the 60-70% SOC range. Then as you said a full charge cycle kicks in. Perhaps that is acceptable to some, but not everyone. Also, repeated cycling and absorption charging at 14V+ could very well cause faster capacity loss than just leaving the battery floating at 13.4V.
There seems to be some debate on what if any effect a float stage will have on an LFP battery. When I searched there were mostly opinions from many years ago in the LFP's infancy. There was consensus that if floating the voltage is important and it should be about the same as the resting voltage of the battery. However, at least on my batteries, it is all just an exercise in arguing, as when my LFP batteries reach 100% SOC and the cells are balanced it goes into a "Standby" mode with 0 amps entering or leaving the battery. It will stay in that mode until a large load is applied or the SOC drops down into the 70s or 80s. I also suspect given the variety of opinions that the loss of life is rather minuscule when compared to the life of the batteries, which is measured in 1000s of cycles and 10s of years.
Likes: Johann
