DC induction cooktop
Apr 5, 2009
3,312
I think this would be marginal. The continuous power rating at 25C is 1000W but my 3kVA Multi will heat up pretty quickly so I use the 40C rating when planning. The 1200VA Multi is rated at 900W continuous at 40C. You can parallel Multis… do you have room for two 800VA Multis?
Also, did you look at the original Multiplus 2kVA and 3kVA? They have different forms than the Mulplus-II.
I had looked at the Multiplus compact before I got my IP22 chargers but I just do not have enough room anywhere close to my batteries that I could install anything that big. I see that the VE-Direct is not offered in a 1600VA in the same case as the 1200VA. I will need to do some rearranging but think I can get this one to work. The reason I am leaning towards this invertor is because it is a low frequency invertor which is much more efficient at 91% than the cheaper high frequency units. In standby, it only uses 14W. You can also set it to ECO mode and the standby current will drop to 1w.
Here is a video from Will Prowse on it.
Likes: Johann
colemj
Jul 13, 2004
1,119
I had looked at the Multiplus compact before I got my IP22 chargers but I just do not have enough room anywhere close to my batteries that I could install anything that big. I see that the VE-Direct is not offered in a 1600VA in the same case as the 1200VA. I will need to do some rearanging but think I can get this one to work. The reason I am leaning towards this invertor is because it is a low frequency invertor which is much more effeicent at 91% than the cheaper high frequency units. In standby, it only uses 14W. You can also set it to ECO mode and the standby current will drop to 1w.
I think you have that backward. In general, line frequency inverters that use a single large transformer are less efficient and use more idle power than high frequency inverters. It is just the physics of keeping that large iron core saturated.
ECO mode does bring the standby draw down, but I rarely find it useful in practice. It works by sensing for a load. If it doesn't find a load, it drops back to a square wave of lower power, thus saving energy. However, if you have anything plugged in that presents a small load, like device chargers, a microwave with a clock, etc, it always sees that load and stays on. If you adjust the set points for ECO to accommodate these small loads, then it never leaves ECO mode and nothing works until you turn it off.
Of course, any comparison of these numbers has to be like-like, and not a Victron Phoenix vs a $100 Amazon no-name. Also, the Phoenix is a very efficient line-frequency inverter compared to others, so I don't doubt that it compares favorably to high frequency units.
The advantage of a line frequency inverter is that it can handle much higher startup loads, and is very robust.
Mark
Johann
Jun 3, 2004
578
Leopard 39 Pensacola
I misread you were looking for an inverter/charger. The specs on that 1200VA inverter look pretty good for a microwave drawing <1100W.
Apr 5, 2009
3,312
Yes, I am looking for an invertor only. they also make a 1600VA for just a bit more money which is in the exact same case and has the same draw at zero load which I will likely get.
Likes: Johann
