I have a Datamarine depth gauge, model S200DL that is acting up. Two seasons ago the readings on the display started jumping all over the place but I'd say 60% of the time showed the real depth in between jumping from numbers below and above actual so I was able to reasonably diseminate the bad readings from good. Last year however, the frequency of 'bad' readings increased to the point where I no longer know what number displayed at any given time is the acurate reading. I've tried adjusting the shallow gain knob on the back of the head unit with no luck. The connections for the power and transducer (DX-110) all appear good/tight and free of corrosion. The front of the display shows signs of weather intrusion as there are stains from where water may have entered the switch on the face of the display for setting/selecting the depth alarm.
I've read some other (limited) threads on this subject with this particular model and have been informed of DMI Marine where it can be repaired.
Since this thing is pretty old, replacements no longer manufactured, and repairs likely costly I wouldn't mind replacing the system with a new model. That being said, I'd like to not have to modify my seacock fitting that the current through-hull transducer is mounted in.
Does anyone have any insight or experience with this transducer type and a same-size replacement?
Or, if someone can convince me that the transducer is the only thing wrong then I will consider purchasing a new one which I have been able to track down online and keep the old head unit. The boat is on the hard so now is the time to address this if I have to play with the transducer and/or seacock. Thanks!
