Brian Faris
I reciently purchased a 1984 Catalina 30 with a Datamarine Corinthian series S 200 DL depth sounder. The gauge was not working when I purchased the boat, but on inspection I found two of the three wires on the back of the unit were pulled out. I replaced the two wire connectors and reconnected them to the terminals. I have also been under the boat to clean the transducer. Does anyone know how to set up this depth sounder ? When I turn it on depending on the position of the switch in the back, I will get a readout of changing numbers or just the letters MSD on the display. Thanks Brian
