Damaged Sliding hatch
26
Catalina 22 Lake Dubay
We just purchased a beautiful Catalina 22 , Circa 1986...but we found that the sliding hatch runners that slide in the wooden rails are cracked.
Any suggestion?
Joe
Jun 1, 2004
8,333
Any suggestion?
Call the Catalina Yachts part dept.... customer service... you can reach them through the general switchboard number at the bottom of the opening page of the website. www.catalinayachts.com
Ken
Jun 1, 2004
1,182
Catalina 22 P. P. Y. C.
This is a very easy repair, first taking off either of the wooden side rails. With the hatch off you can use blue masking tape as a mold to hold the epoxy in place while it kicks. From there you use fiberglass tape to build them up until you reach the desired thickness.
26
Repair Hatch
Thanks for the information....nice site!
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
My 25 was the same. I removed the hatch and sanded and cleaned the fiberglass and added a few layers of fiberglass sheet and resin to build it back up. All the added material was to the under side of the hatch. Worked out well. I bought the sheet and resin at an auto parts store that handles body shop supplies. While I was doing that I also sanded and finished the track rails. Not a hard job just takes some time. Reseal the rails to the deck when re-installing them. Good Luck
mortyd
Dec 11, 2004
952
Catalina 30 easy living
yes, catalina direct sells parts that may or may not be genuine for more money than catalina yachts. you chose.
