dagger board leak
Dan Nolan
I have recently purchased a 26D Have noticed slight damage to the dagger board compartment(stress cracks and chips down the length of the box) and occasionaly take on water in choppy water what is the best meathod to resolve this problem??
Jun 4, 2004
618
- - Buffalo, NY
First...
try to find out where it is leaking. Take the daggerboard out and plug the bottom...fill the trunk with water and look for the leak. Hopefully it will be in a location that is accessible...which it probably is...at least above the ballast tank. Good luck.
Ramblin' Rod - Mac 26D - SeaQuell
Checking for leaks
Dave's idea might work. But unfortunately the column of water in a plugged trunk doesn't generate near the force 3000 and some pounds of displacement does. I'd recommned laying paper towel around or marking around the base of the dagger board trunk with washable markers, just before launching. The paper will wet out, or marker lines will streak where the water contacts first, indicating where the leak may be. If the daggerboard trunk is truly fractured down its length (doubt it) rather than where it meets the hull or the leak is coming from somewhere else (more likely), here's what I would do: 1. Sand down the insides of the trunk. (A sanding block on a swivel pole should work.) 2. Apply a thin coat of thickened epoxy to the walls. 3. Let cure and then try the leak detection trick in the water again.
