: D Got me a chartplotter!!
KandD
Jan 19, 2009
193
Hunter 40 Corpus Christi
Got myself an A70D! so psyched! West Marine is offering $200 gift card and Raymarine has $500 rebate, so it's basically half off! Now I just need to build a console to hold it and my other displays.
I'm not sure where I'll put the transducer...
Jun 2, 2004
5,802
Aren't there different transducers? I think the standard one is for transom mounting. Does that mean there is a cable hanging down the back of the boat?
KandD
Jan 19, 2009
193
I think so, I emailed raymarine to see if I can use the ones already installed, but they are from '94 and '84, so I'm not sure if they will. The transducer is individually packaged, so I may try and exchange it.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Transducer mounting
You can use a transom mount transducer shooting right through the fiberglass hull. Several on this board have done it. Put it in a baggie of water and move it around inside the hull till you find a good spot. You want to be sure you avoid any bubble in the glass. When you find the right spot stick it down. Several ways to do this. Some use a piece of PVC with a cap. Some like me, just stick it right to the glass. I used Marine Tex, but some on this board have just used a blob of silicone caulk. Apparently that works as good as anything. Just make sure there are no bubbles in whatever you use to stick it.
Joe
Jun 1, 2004
8,352
So he got a chartplotter/sounder... right?
