Cutting through fibreglass core decking suggestions?
30
Seidelmann S299 New Brunswick Canada
Hi,
I am replacing the forward hatch of my Seidelmann S299 and need to cut out the decking for the old hatch to enlarge the area for the new hatch opening.
Does anyone have suggestions on the right tool for the job? Handsaw or mini-grinder or recriprocrating saw?
Thanks all,
Peter
Tim R.
May 27, 2004
3,626
Peter, how thick is the deck there? Is it cored? How much bigger do you need to make the hole? I used a sabre saw to enlarge some portlight openings last year and that worked great. There was no core and it is 9/16" thick. I used wide blue painter's tape to protect the surrounding gelcoat from the saw foot.
RichH
Feb 14, 2005
4,773
Tim R.
May 27, 2004
3,626
Multimasters are great but mine did not cut the 9/16" solid fiberglass very effectively.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I bought the cheapo Dremel version of the Fein for $100 to cut through my coaming. It worked fine and provided excellent control. Just make sure the blade is tight and the washer is in the correct orientation or it will loosen rapidly.
Tim R.
May 27, 2004
3,626
A sabre saw with a fine blade should work well then. Make sure you seal the interior with plastic around the opening you will be cutting. Otherwise the dust will get into everything.
RichH
Feb 14, 2005
4,773
Adjust the amount of vibration to 'slow'. Dont let the blade get too hot and it will cut right through. If the blade gets too hot, the teeth will quickly anneal and rapidly lose their sharpness ... just like 'any' sawblade will. You can also spritz water into the cut groove to help cool the FRG. If any blade is smokin', youll quickly wear it out.
Ross
Jun 15, 2004
14,693
With a saber saw you can cut to your line. That is as precise as you need to get. Use bi-metal blades and if they get dull change them. They are consumables and aren't expected to last forever. Protect the inside of the boat from cutting dust. If you can tape a slack plastic sheet under the work area that will be good. Also as others stated seal all of your cut edges.
Sep 25, 2008
2,288
However you cut the hole take Ross's advice and tape a piece of plastic under the hole. You will literally have to take a hose to the inside of your boat to get all the dust out if you don't.
If the surface is flat, my favorite tool to cut fiberglass with is a router with a 1/2" bit. If you take the time to make a wood frame for a jig, the edge would come out looking so good you won't want to install the hatch and cover it up.
Dec 11, 2008
1,338
catalina C27 stillwater
I agre about the precision edge a router gives, but wow, that is a wide kerf!!!!
To me it would be better to rough cut with anything, and then trim to "the line" with a router in a jig frame.
Ross
Jun 15, 2004
14,693
Since the hatch frame will cover the cut, the exact line of the cut is not very important. The opening must be large enough for the hatch and not so large as to make bedding the frame properly impossible.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Use a circular saw, it will remove most of the cut really fast. Then use the fein or saber saw or router or a hand saw to cut out the corners. Also a rotozip would work for this as well, they have all kinds of attachments for various cuts.
Sonya
Oct 9, 2007
19
Mirage Sloop 25 Spanish, Ontario, Canada
Hi Peter:
Safety thought, keep fire extinguisher handy, things tend to get very hot very fast and where there's smoke there can quickly be flame to follow, and fiberglass afire isn't easy to extinguish once it gets going....
Best of luck with your project.
Sonya
Ross
Jun 15, 2004
14,693
Sharp tools cut well, accurately and easily. If you have to start forcing the cut you probably have a dull tool and it is time to change. Sharp tools won't/don't overheat.
BobM
Jun 10, 2004
3,269
I'd pass on the rotozip
I have one and that is a tool that loves to wander!
Sep 4, 2007
30
Ok,
Here is what worked the best. I used an angle grinder and a metal cutting blade for the long straight cuts. It is like cutting through butter. I used the sabre saw to carefully do the corners! Thanks for the help.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
We cut the hole in our deck for a new hatch, see http://tinyurl.com/kor9vc
and we cut the hole with a Makita skill saw and a carbide blade. Finished the corners with a saber saw and a carbide blade. Chuck
Marcia
Mar 26, 2007
123
Paceship Yachts PY23 Cove Marina, NAB, Norfolk VA
I used an inexpensive Dremil tool. Worked great and didn't leave me with a wide gap to fill.
Aug 2, 2005
374
pearson ariel grand rapids
I'll recommend the circular saw. Depth control is much better with it. (in case there's something inside you DON'T want to cut!) If you do adjust depth, mark the shoe so you know where the blade is for accuracy.
Mark out the cut, then use a hole saw for cutting out the corners, finish off with the circular.
Helps to have a helper hold the cut-out level when making the final cut, or tie it up so it doesn't drop in. If unsupported it may rip out some of the glass inside leaving you with an unwanted repair.
I prefer the porter cable saw-boss, works great for it. PC saws have the guide tube so you can direct the exhaust where you want it making clean-up a bit easier.
Ken.
