You probably could, but it would require proper tooling, removing the propeller, and scuba gear.
You don’t need to go to Hunter to get the part...you need to know the shaft OD (the ID of the bearing), the ID of the strut (the OD of the bearing), and the length of the strut ( the length of the bearing), then you can find the proper bearing. You may be able to find it here on the site...
Here is a video I made using home made tooling to press out my cutlass bearing (on the hard). It will at least give you an idea what you are getting into...
If all goes well, and you have the proper tools, yes, it can be done in a day.
