I need to replace my CB as it is showing a bit of vertical wear. I have a shaft log with no strut, and I have been trying to come up with a way to press the new CB in w/o removing the shaft.
This is the idea I came up with and I am looking for flaws in my idea:
I want to use a spacer, a couple of washers (per MS idea of greasing two so they don't bind), and using the the prop nut as my 'press'. The two obvious areas that concern me is damaging the thread on my SS shaft or somehow altering the press of the coupling on the Tran. side. My coupling has two dimpled set screws and I may attach a donut zinc on the shaft to help offset any pull. My thinking is that the prop in reverse generates plenty of pull, but still wanted to get some feedback. Good idea??
