jake
I will be hauling out in a two weeks and I want to write [ie speak]to someone that might have replaced a cutlass bushing in the past. I can tell you that at this point I have no reason to believe I need to replace this bushing. Is there a way for me to determine if this bushing is wearing out? I understand that if the prop is loose or frozen this must be done.Today the prop spinns under power and there is no screaching.There seams to be no vibration coming from the prop.It seems I wont know until I see the bushing. If you have replaced one I sure would appreicate any advise on getting this out.If the shaft is frozen on the bushing it seems cutting the shaft and beating it out might be the way to go? is this what you may have done? if not please let me know. she is coming out over the three day week end so I'm investagating now. THANKS FOR YOUR TIME AND ADVISE JAKE L.
