Hey everyone,
Im pulling my newport 30 mk2 out of the water next week to try and fix an engine alignment issue. I believe the cutlass bearing is badly worn and the engine is extremely misaligned. I plan on hauling the boat, pulling the shaft and shaft coupling and pulling the engine back to start things fresh.
My questions are a plenty....
Is there any way to size a cutlass bearing before I haul out? The lift is in a very isolated place and parts need to be shipped in.
The current shaft coupling is a flexible press on monster of a beast. I cant seem to find anything that resembles this at online marine stores. I can only find rigid couplings and drive savers that go between the transmission flange and the rigid coupling. Am I missing something? Is it still possible to find an all in one flexible shaft coupling?
The current coupling is 40 years old and is too badly rusted to make a proper engine alignment practical. Its connected to a universal 5416 with a hurth z50 2:1 transmission. Hopefully I can pull it without destroying the shaft, or should I just plan on putting a new shaft in from the start? What would a new ss shaft cost?
I also plan on installing a pss shaft seal belows kit since the original bellows is no longer up to the task. For this I need to know the stern tube diameter. Is there any way to find out what the stern tube diameter is before I pull the boat? The shaft is 7/8ths stainless.
My 16hp universal sits on only 3 mounts. The aft mount (forward? closest to the bow?), is turned 90 degrees to the two side mounts. This makes adjusting the engine impossible once the bolts are in. Is this normal? This seems to make zero sense to me. All lateral adjusment of the mounts is restricted by this sideways mounted mount.!?!?!?! Currently the thwart-ship engine stringer is too narrow to turn the mount 90degress in line with the others. I have the materials to glass in a block of hardwood which would make it possible to turn the mount 90 degrees. Is this advisable?
I will try and post pictures tonight.
Any info, links, tips or suggestions would be great as I start this challenging process.
