Cutlass replacement thoughts
Tom,Replacing the cutlass bearing involves pulling the prop & and the shaft. A certain amount of water is going to get inside as a result. While I suppose it could be done with the boat in the water in an emergency, I think a better quality, less messy job would be done with the boat hauled. Suggest you review Nigel Calder's book on boat maintenance to review what is involved, regardless of how you have it done.Pulling that bearing under water can be a fairly easy job with the right tools, but inspecting the bearing seat in the strut is difficult, and man-handling the shaft etc. can be a challenge. If there are complications ("Murphy" rules!) they are even more complicated with the boat in the water. Awfully easy to loose parts under water, too.Regardless of how you have it done, make sure the shaft packing gland is adjusted properly afterward, and do a shaft alignment. Shaft mis-alignment was probably the cause of the bearing failure in the first place. If you haul each winter, the shaft alignment should be checked after you step the mast & tune the standing rigging as part of the in-the-water commissioning.--Ron
