Michael Ryan
I recently had the cutlass bearing on my '86 Hunter 34, for some reason slip forward and come right out of the strut. Fortunately I noticed the unusual rattling sound as I was leaving the marina.I dived on it later and was able to press it back into place without too much drama, but that must make for a loose fit. I noticed that one of the set screws was intact but had worn away it's threads in the strut and the other one was loose. I was able to tighten it down after resetting the bearing. I would recommend every Hunter owner check these next time you are out of the water (or under the boat). A friend who owns a 37', had the same happen to him. He believes that on installation, that they failed to make an indent in the bearing sleeve for the set screws to get a bite onto. I am planning on leaving it with the one set screw until I haul it in the spring but as an added safety feature will slide one of the shaft annodes down close by the strut so if it does happen again it won't come out as far.Any others have the same problem?
