Steve
I have a 1992 Hunter 28 that needs the cutlass bearing replaced. Has anyone removed the cutlass bearing without removing the prop shaft? It appears like the rudder must be dropped in order to get the shaft out and I don't think I'm up to the task. While I'm on the subject, it there a good (accurate) way to tell if the prop shaft is bent with the shaft still installed in the boat?
