Richard
I have a 1983 Hunter 34. At low engine rpm there is a vibration / rattling sound in gear. As rpms increase the noise gets more quiet but there is still a growling sound at the the rear of the boat. We suspect the cutlass bearing is the problem. Where the shaft comes out of the boat is a metal ring that the shaft appears to be rubbing one side. The boat yard suggests the the cutlass bearing needs to be replaced. Any suggestions? Does the rudder need to be dropped to replace the cutlass bearing? I have checked some of this forum and can't find an exact answer.Thanks Richard
