Cut my sail down?
18
2 Hunter23 Croydon,Pa.
The main on my 86 Hunter23.5 hangs too low at the stern, when it swings across you better be sitting with your head down a little.
I was wondering about cutting and resewing it. The sail itself is in decent shape, I don't want to ruin it. It is a hunter sail, whether or not it was for this boat I don't know. How do I go about deciding how much to take off? Any help is appreciated. Thanks- Jeff
Alan
4,174
Hunter 35.5 LI, NY
'86 main?? If that's the original sail sounds like your main is blown out of shape big time. How did you decide "decent shape"?
My advice, have a sail-maker take a look at it and give you his/her opinion. Sailmaking is a 'black art' and anything that you will do to it will probably not work.
3,670
They all do That
When out for just a leisure sail I pull it up with the topping lift otherwise you'll learn to duck.
Jun 28, 2009
312
hunter 23 Lake Hefner
Sorry Rick, I have to disagree. I have an original 1985 main that hangs just like the OP describes. This happens when the sail material has stretched too much or if the luff rope shrinks. I just recently inquired to a sail loft with just this very thing. That was his response to me. He said to send him the sail and he'd see what he could do. This would range from replacing the luff rope up to cutting a "wedge" out of the main to shorten the clew end of the sail. I'm sure all of this is predicated on the sail actually being worth a darn, which I suspect it probably isn't worth the postage to send it to him.
I'd bet your main is in the same sorry shape mine is. Fortunately, I have a J 22 main that fits fairly well - not quite as big but does well enough until I get one made for my 23. I'd rather tack and jibe without the risk of getting bashed and have a mismatched sail than have my original main :eek:
And yes, I've already had some punk kid give me heck for having an incongruent sail and boat. :doh:
Jun 28, 2009
312
BTW SS,
In your profile it says you have a 1985 23 and in ur post it says 1986 23.5... So what u got :) Also, I like your sig. My kids and I are fans of Jack Sparrow. And I'm a fan of rum :D
3,670
It has Been Posted on the 23.5 at Least a Few Times
Guess it was not an issue on the 23. I should have read it closer.
May 4, 2009
18
The boat is an 85, I was hoping to impress people by saying it was and 86. LOL!.
Typing is not my forte'. The sail itself is still "crinkley" (if thats a word), and there are no tears or bad seams, I would guess that is Blown out, But where I come from we use them til they are only able to be used for fishing nets. Why? I dunno, some kind of weird fixation on keeping them as long as one can!- J
Jun 30, 2009
9
2 28.5 Lake Norman NC
I'm having a bimini installed on my 1985 Hunter 28.5 and will have a sail loft take a "wedge" taken out of the original, now baggy main to accomodate decent headroom - and reduce the bagginess. I used the topping lift to pull the aft end of the boom up for the bimini, and the boom is approximately horizontal. I will "reef" the mail slightly to sail until I can have it recut. I'd say definitely get a sailmaker to do the work.
May 4, 2009
18
I was installing a bimini too, that is what started this whole thing. I think I may kick around some new sails until I get a price on the sail repair. Thanks All!!!- Jeff
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
Ah yes... the dreaded bimini top-- bane of performance sailing everywhere! Ha-ha.
I took my aged main to the friendly neighborhood sailmaker and he replaced about 9 inches of bolt rope due to shrinkage. This had meant that the sail would never have pulled up to taut along the luff. This cost me $67. So I ordered a new mainsail cover from him too.
I would have the sailmaker come down to the boat (they all make 'boat calls' if you let them schedule it) and pull up the main to let him see it. Listen to his recommendations. If this is just not an option at all, then you pull it up, leave it stand alone, peaked, at the dock and take as many photos as you can. Then take him the sail and the photos. He will advise you about how much to cut off and on the issues of accommodating a bimini top in the first place.
Remember that trimming off the bottom of the main does 2 very bad things-- it reduces sail area at the biggest chord of the sail and raises the center of effort, thus imposing greater heel angle in less weather (the boat becomes more tipsy). Further, sailing with the bimini top up adds windage, weight, and uncontrollable sail area, and inhibits your ability to see and adjust sails, all of which are detriments to sailing performance which will detract from the experience of actually sailing.
About the only thing a bimini top improves is the experience of actually sitting in the sun, and you can wear hats for that when under way. (My dad used an umbrella clamped to the rail.) And being able to sail better when under way means you'll get to the mooring sooner, and it means have less time sitting in the sun while under way and more time sitting under the bimini top when moored.
Ask the friendly neighborhood sailmaker first.
May 4, 2009
18
Well Thanks for that advice, certainly will be the route I take, hope to see you on the Delaware.- Jeff
