Customizing your boat
A
Al Carlson
There's always something additional...
Additions to a new Catalina 36 MkII include all Raytheon instruments with radar, chartplotter, and autohelm. I also added Marine Airrrr AC/heat, electric macerating toilet, Pioneer AM/FM CD changer, JBL speakers in cabin, Sony speakers under rear-rail seats. An insulated backstay and Dynaplates on the hull (for grounding) prepare the way for an SSB. Adding tank monitors for 3 water tanks and holding tank. I'm far from done -- my list continues, seemingly unending.... Funny, I always thought that retirement was where you spent LESS money than when you were working. Photos are available on link below. Wishing you fair winds and kindly seas, Al Carlson S/V Wings of Dawn
Tim Schaaf
YIKES!!!
Gasp! Let me preface this list with the comment that, since I will celebrate my 20th anniversary with Casual Water this February 4th (I live aboard), I have actually had quite a bit of time for sailing, notwithstanding the following: Ground Tackle: added bow roller and custom built a "pawl", changed cleat and chocks, bought five anchors and assorted chain, line, swivels, shackles, etc. Sails: new sails, plus storm jib and interior forestay, cruising spinnaker. Added whisker pole and gear. Steering: replaced Kenyon steering cable, added autopilots (2), and Monitor windvane. Structure: beefed up a few areas, most importantly the hull aft of the keel joint, the root of the prop strut, and the whole interior and mounting system relating to the rudder tube assembly, bearing, and quadrant. Galley: replace Kenyon stove with Origo 3000 and gimballing microwave, and added Magma propane BBQ. Installed Supercool refrigeration unit. Changed faucets, added transparent doors to lockers and ice-box shelves. Installed manual trash compactor and watermaker. Head: replaced head, added holding tank, changed faucets, shower, added sun showers and pressure sprayers, above and below (great equipment). Entertainment center: installed AM/FM/ Cassette, speakers, and CD changer, TV and VCR. DVD player to come! Electronics: installed Loran, GPS (3), Ham/SSB, radar, new VHF, knot meter, portable electric piano, EPIRB (2). Interior and cabin: changed ports, replaced cushions and blinds, added a few pictures and carvings, various gear hamocks, rugs, converted pilot berth to shelf, made another shelf. Engine: routine maintenance and replaced water pump and elbow (several times each) exhaust hose, water lift mufler, painted engine. Plumbing: changed all gate valves to ball valves, and added a few. Pumps: added a high capacity bilge pump (3000 GPH, measured, and a manual bilge pump) Electrical system: installed smart regulator and spare, and smart charger and four golf car batteries and upgraded alternator, and installed 1700 watt inverter and several new outlets. Installed 324 watts of solar panels (8). Added masthead running lights and foredeck light. Exterior: either Awlgripped or re-gelcoated all exterior surfaces, did blister job, painted mast, and applied name decals. Built seahood (garage for main hatch), re-bedded all hatches, added radar reflector, dodger, several awnings and arch over helmsman's seat for solar panels. Made wave deflection washboards for side decks just aft of winches, and scuppers for the waves thus deflected (SINGLE BEST ADDITION TO BOAT!), and added various types of cushions for various conditions. Installed MOB gear plus LifeSling, made davit for outboard. Rigging: re-rigged (twice) and upgraded to larger, 316 wire and Norseman mechanical fittings, and changed the split backstay to twins (one insulated for the Ham/SSB antenna), which really opens up the cockpit. Toys: added various dighies and outboards, over the years, with the current complement being an Avon 315 with Evinrude 8HP outboard, a Tinker Tramp sailing dinghy/lifeboat, and a Stearns inflatable kayak. Well, I may have missed a few things, but that is about it. Many items have been done more than once, as I have upgraded things and bought newer versions. Most, but not all, of the work was done by me. I had the advantage of buying an almost new boat, to which the owners had added nothing. Everything works!
N
Norm Copp
Cat 30'-- 13 improvements
1. Installed curtains with the cheap round rods and sewing curtains to fit. 2. Installed a 6 inch dia. window on starboard side in the cockpit to light below aft sleeping area. 3. Installed a 4 inch dia. window on the top section of the v-birth. 4. Moved the engine shift controls up 11 inches from the floor. 5. Moved the engine control pannel to the top port side. 6. Installed a wash down pump and hose in the anchor well. 7. Installed a pull out shelf in the aft birth so our heads are in open space when we sleep. 8. Installed davits to carry dinghie. 9. Installed GPS on pedestal guard. 10. Installed skipper chair in aft section. 11. Added circuit to read separate voltage for each of 3 battries. 12. Installed day/night vent. 13. Installed anchor roller.
Bud Harrell
More storage
Hunter is a fine boat, but when you try and live on one just for a few months, you find there is damn little place to put everything. So, in the Captain's cabin, I took the entire stb. side and made a cabinet for storage. Same thing for the V birth, I made a cabinet forward of the hatch which provides room for anyone, like my grandson, to put his "stuff."
john citrolo
change battery location
I had the battery locaation changed from the inaccessaible starboard lazaret at the swim platform to the sarboard lazaret in the cockpit.
C
Chris Gonzales
Will be finished this summer....
A lot to do on this '79 C30 when I purchased her. She had a perfect hull and a fresh smelling, nice looking interior and the little 5411 runs like a top. So we felt investing in the upgrades would provide a virtually new boat and still we would have less money spent than buying a newer year model. If anyone wants more detailed information on the upgrades/mods, write cg2chris@pacbell.net ** Items on order will be here within 2 weeks! * to be accomplised this spring/summer Rigging/Sail Handling Replaced all standing rigging including bow bobstay Replaced all halyards (4) Installed new ProFurl NC32 furler Added furling blocks and line New 135% Tasker jib and full batten main sails New vinyl coated wire topping lift Double line reefing installed Installed flat mainsheet traveler ** Installed new rope clutches (2) ** Installed new rigid boom vang ** Replaced (2) sheet winches w/46ST** Replaced (2) halyard winches w 28ST* Hull/Deck Repaired 6 blisters on bottom Painted bottom Replaced zincs on prop shaft (3) Changed name from “Water Wiz” to “Cg2” Replaced head port with opening port Replaced forward hatch support Waxed and polished hull Tightened keel bolts Installed new steaming/deck light on mast w/new wiring Installed Catalina lower shroud chainplate upgrades (4) Added new winch covers (6) * Added new cockpit cushions * Re-varnished all exterior teak * Re-set bulkheads and secured w/bolts and straps top and bottom * Replaced smaller starboard window with opening port * Painted deck * Replaced all cockpit locker and anchor locker hardware * Installed dodger * Interior New foam cushions/upholstery New double light fixtures (4) Cleaned teak in galley area Oiled all teak Added 28x12 teak door in galley (to allow easier access to plumbing and valves) Installed new sink drains and hoses New carpet * New galley and head countertops * Engine Added new stainless bolts/nuts to engine mounts (4) Painted rusty mounts, misc engine parts Replace filters, fluids * Check shaft alignment * Plumbing/Electrical/Appliances New Origo 3000 2 burner stove New Jabsco head Replaced ball valves on thru hulls (2) Replaced permeated sanitation hose* Replaced gate valve on macerator line * New galley and head faucets ** Added 110V outlet to galley * Installed holding tank reader * Installed battery charger/meter * New 2,500 GPH bilge pump w/switch There was a lot done already that seemed to take forever to do at one or two days a week effort. Much more to do, but hope to be finished this spring and be able to enjoy the boat this summer and fall. Planning at least a week up the Sacramento Delta. Chris
Tim Schaaf
Improvements addendum
I forgot to include the following items which I think are important for offshore sailing: installed positive latches, bolts, etc to secure floorboards, compartment lids, and drawers in case of knockdown, installed gasketting on all cockpit lockers and covers for all vents, thereby permitting a completely watertight cockpit, installed Spurs linecutters, and installed Dripless stuffing.
C
Capt. Kimo
Upgrade 96' MacGregor 26X
>What have you done to customize your boat to suit your tastes or >requirements? • Magna "First Mate Dual Mount" cutting
JASON ROZNOS
MAC 19 Helm?
WHERE DID YOU MOUNT THE WHEEL??? THANKS, JASON ROZNOS JASON@CALLISMA.COM 941-907-2620
Robert Tuten
engine upgrade with Speedseal
I noticed that no one mentined engine upgrades. I have been studying the Speedseal water pump cover. Has anyone installed on of these on their engine? How do you like it? Is it as good as the manufacturer says? was it easy to install?
SailboatOwners.com
Final results
Final results for the Quick Quiz ending 1/27/2002: The largest changes I've made to my boat have been:    43% Functional equipment like sails or anchors 27% More electronics  21% Appearance upgrades  08% Left well enough alone
Tim Pastushin
C250 Upgrade
We took our 2000 C250 Water Ballast and added a few improvements: 1. raytheon speed and depth 2. raytheon tiller pilot 3. installed a marine head with holding tank in place of the porta pottie 4. installed a macerator pump with overboard discharge 5. electric fans for each settee and two for the aft berth 6. replaced the factory table with a teak and holly table made from remanant stock bought at marine surplus stores 7. led all sail control lines back to the cockpit 8. various teak storage racks for books and magazines 9. Magma BBQ - of course
Michael
Drawings or pictures of mini-galley?
Jim, Do you have any drawings or pictures of your mini-galley that you can upload to this site or e-mail to me? I'd like to do something similar on my V21 but can't figure out how to get started. Thanks!
