N
Neil
For various reasons I need a custom engine hoist to handle a not too heavy outboard motor to be mounted on the stern rails of my sailboat. None of the standard units will fit and these suppliers don't seem too interested in making up a custom unit. So I am hoping to find a shop that will cut, bend and TIG weld SS tubing. There is not much to it as far as I can see. Cut to length, bend tube to spec and weld on an eye to attach a pulley block lifting system. I could probably come up with a rail mounting device for the hoist without too much brain storming. However the real challenge, as I see it, is the foot of the hoist post needed for the deck mount. It needs to allow rotation but not allow the post to accidently lift out.Has anyone successfully designed and fabricated a custom outboard engine hoist and solved this design/fabrication problem?
