Cursors Gone Wild
2,955
Hunter 38 Georgian Bay, Ontario, Canada
port or starboard
but was the crazy ivan to port or starboard?
Jun 30, 2005
31
Oday 25 Sardis Lake, MS
What time is it
Tell me what time it is and I will tell you if his going port or starboard. I don't really know but I have a 50/50 chance and I need a break.
Feb 17, 2006
5,274
It was to starboard, or course...
Because Ramius always goes to starboard at the bottom of the hour. ;)
Oct 26, 2005
116
Oday 28 Detroit/Grosse Pointe Park (O'Day 192, O'Day 28)
submarine, house batteries
Stuart - you could probably get this on a trailer: http://www.engadget.com/2006/07/11/u-boat-worx-set-to-release-cq1-personal-submarine/ Everyone else who uses a laptop onboard - What type & size house batteries do you use? How long can you run your laptop before recharging (the house batteries, not the laptop)? Do you leave your laptop on to track your course, or do you plot your course, put it in standby, then check it occasionally? Thanks, Kevin
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Kevin
I use a HP with a Centrino cpu running on a 150 watt inverter while I'm moving. I don't worry too much as we have been on the hook for 3-4 days with the refridge running using lights to read, and some music on the stereo (the laptop isn't running all this time), and I can still start the engine using the house bank (I have a starting battery). My house bank is 4 Trojan T105's configured as 2 12v batteries which I combine using the 1-B-2-Off switch. Totoal amp hours (new) 450. They are in their third season.
Mar 4, 2004
347
Hunter 37.5 Orcas Island, WA
Kevin II
Our house bank consists of four 6 volt golf cart batteries wired in two pairs with 400 amp hours of total capacity. We have a Balmar 110 amp alternator. If we're out cruising we pretty much leave the computer on all the time for navigation. Winds tend to be fickle in the Pacific NW, and if you're trying to get from point A to point B in a reasonable period of time, most days you end up motoring at least part of the time which has been plenty to keep our house bank charged up. We also have a separate starter battery. Hope this helps. Gary Wyngarden S/V Wanderlust h37.5
Jul 9, 2004
80
Yamaha 30 - Sidney
mouse /GPS conflicts
Caveat: Not a computer genius posting! However .....if I recall correctly, a buddy of mine was having the same problem with his setup a couple of years ago. Again, IIRC, it turned out to be... (grossly over-simplified here) ..... the computer seeing the two serial devices as the same thing and therefore trying to respond to input from both at the same time. I believe it was resolved by different "port assignments" in the operating system. It was definitely a system software though, not environmental. Now when my tillerpilot started darting all over the place while motoring home in the rain, that was environmental! (leaking past the rubber button seals onto the pcb) cheers all Craig
