Hi,I am considering buying a Macgregor 26s. It will probably be on its trailer most of the time (ie not moored in water) and will see salt and fresh water. What is the current wisdom regarding the need for bottom paint? The boat currently has paint on it but the paint job is at least 5 years old and needs to come off. Do I clean it off and just wax the bottom or do I clean it off and put on a new paint? If the verdict will be to repaint then what do you recommend for a boat that will not be kept in the water most of the time?thanks in advance,Lori
