Curing a Heavy Weather Helm on a Hunter 27 (1981)
Dave Simpson
I have read numerous owners' review that mention a heavy weather helm on the Hunter 27 (1981). Having just purchased our Hunter 27, I haven't been on it enough to determine if this is the case with ours. If it is, I'd like to do what I can to cure the problem (if possible). I would greatly appreciate anyone who has an opinion about this and a method to do something about it. Thank you, Dave
td4321
Jun 7, 2007
18
Hunter 40 Tred Avon River
Hunter 27
I had a lot of weather helm on our '81 Hunter 27. What I found was the best cure was to put a reef in the main early. It took us a few years to try this and we were glad we did. Good luck and happy sailing.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Weather helm
When you get right down to it, there are only two basic ways to eliminate weather helm. Sail trim and reducing sail area. There is a learning curve to getting a boat balanced, but it's worth the effort. A properly trimmed boat, should sail with very little helm input. So sail the boat, play with it, experiment with it, and you will find that balance.
Jun 14, 2005
165
Cal 20 Westport CT
Tuning makes a difference too
Other approaches you can try to reduce weather helm: Shorter headstay (mast less raked back). Tighter upper shrouds (mast less bent to leeward).
tweitz
Oct 30, 2005
290
Beneteau 323 East Hampton, New York
Weather helm
You can also reduce weather helm by adjusting the trim of the boat fore and aft. The further aft the center of effort in the sails, the more weather helm. So being sure to keep it lighter aft and heavier forward makes a difference. In addition to movable ballast (people), things like the anchor (especially with chain), fuel, etc. can make a difference. Water and fuel weigh over 8 pounds a gallon, so a 20 gallon tankful can affect your fore and aft trim, especially if it is near the bow or stern. If your whole crew sits at the very back of the cockpit, you can reduce weather hlem by simply moving them forward.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Dick is correct
The first thing i would check is the mast rake. Make sure that it does not exceed 1%. This rig should have a backstay adjuster. This is vital to flattening the main which will depower it and minimize weather helm. Sail condition is also a prime factor. If your main is old and blown out you will never be able to adjust out the power of an overly full main. In this case you will have to reef early. With a good main and proper sail trim you should be able to see 18kts before reefing.
Benny
Yes, tired, old, blown sails is the main cause for
excess weather helm on these boats.
