Doyle Spinnakers
Doyle's sails are very well made and designed, their service and support are excellent, and their prices are competitive. The Doyle asymetrical works very well on our 356 and provides a significant downwind performance boost. We use a sock, which makes it very easy to set and dump-even single handed (with autopilot!) we installed spin winches, but you can lead the sheets forward from the turning blocks on the arch to the jib winches.You might also want to consider their UPS (utility power sail), which gives up some downwind performance (less area and flatter) in return for upwind performance (close reaching)in light air. also sets out of a sock, but is a laminate fabric instead of 3/4 oz nylon. we also had Doyle build us a new jib and swingbatten main to replace the Hunter delivery sails and have been very impressed with the quality and support from Doyle. The 356 is the smallest mast section they've tried a swingbatten on, and they made a number of design changes to make it work properly-but they persevered, and made sure that we were happy! the new main/jib adds 1-2 kts upwind, and the chutes add about the same downwind-get you there faster, and are a blast to sail with!
