Crunching sound on deck
langg
Oct 16, 2008
8
Hunter Vision 32 Nashville Shores Marina
We are considering purchasing a 1989 Hunter Vision 32. I noticed while looking at the boat and walking around that there was some crazing which i assume is normal for a 20 year old boat. I also noticed a slight crunching sound while walking on the non-skid areas around the boat. Is that a sign of a serious problem or a normal problem or one i should just run away from. The boat is in pristine condition visually and very well kept. Looks almost new. but with a price tag of 39k im a little concerned. Also the engine smokes when first started. Just a little puff then its gone..is this normal. I have had o lder smaller sailboats that had crazing and it didnt seem to cause problems but this is alot mor money.
Thanks for any help you can provide
7,733
Alden 50 Sarasota, Florida
I would temporarily ignore the smoke puff upon starting. Although it might be indicative of an engine problem, an engine survey by a (good) diesel mechanic as part of a pre-purchase survey would address that variable.
The deck noise, also something which would be investigated by a good surveyor, indicates either rotted core or more likely delamination of the deck. It certainly sounds like one or the other and depending upon the extent, could be a costly repair.
Rick D
Jun 14, 2008
7,206
Crunch
I tend to think it's no big deal. Unlike a stayed rig, the Vision deck doesn't work much and there isn't a lot of places for water to enter. Mine had a little crunch from new up on the forward deck and it was dry as a bone. By all means, tho, be sure to point it out to the surveyor. (Having said that, lots of those guys have no clue how to interpret a moisture meter reading.)
