huh?
Greg,Not sure what everybody else is talking about...luff down the center?? Yes, you can get a furler for CERTAIN A-sails (you can't furl all of them...they have to be cut a certain way to allow it), but that wasn't your question. The tack is held down by the tackline. Click here for a picture. http://na.northsails.com/Cruising_Sails/CruisingHome.htm You can see the red line going from the tack of the spinnaker to the very front of the bow. This line may or may not be adjustable. A non-adjustable tackline is easy to make. Just cut a length of line, attach it to your bow, and attach the other end to the tack of the asymmetric spinnaker before you hoist it. Then you would adjust luff tension with the halyard. (You want a tighter luff when reaching, for a flatter sail, and a looser luff when going downwind, for a baggier sail). If you want an adjustable tackline, you put a block up at your bow, then get a long line, tie one end to the tack of the spinnaker, then lead it through the block and aft to the cockpit and cleat it. Now when you need to adjust the luff tension, you just ease a little bit of this line out. For more info on trimming asymmetrics, this webpage looks pretty informative: http://www.u20class.org/tips/newsl_p1.htm Also, there's a bunch of great overview and tips in last month's Sail magazine (August: http://www.sailmag.com/toc/0805toc/)EDIT: I just found a terrific set of videos online that go over all the aspects of preparing an asymmetric, setting, gybing, and dousing it. Check it out: http://na.northsails.com/video_gen/
