Cruising Spinnaker
MIke Schiele
I've got an 86 Oday 272 with a roller furling genoa. I want to set the boat up to use a cruising spinnaker (poleless). If anyone has any experience setting one up I would appreciate your advice. what halyard is best to use Spinnaker of genoa? Where did you place the tack block? What size spinnaker? Anything else that would help me avoid problems.
Bill (Bahama Bill ) Kingsbury
How to bend a cruising chute
Mike, I have a cruising chute for my '28. No additional gear is needed. Although I have a pole, I loaned it to a friend and have never used it. I had to add a short line to my tack block to raise the sail high enough to clear the bow pulpit. Any stout rope will do. I use a second halyard. Re setting the sheets, my track is so long that I have no trouble setting my sheets. I use my regular jib sheets. Get one and use it. They're a hoot! Your friends will think you are really cool when you bend one. I am not a sail specialist, so I would contact a sail loft re what size. I think that the "I" is your number to use, ie the length of the luff on your other jibs. If you don't know that, email me at kingsburywebill@hotmail.com. I have an original glossy brochure on your model in my file that will provide the "I". Actually, any sail loft will have your "I" and can make recommendations. There is a loft on this site.
