Jeff Powell
Would like to add a cruising spinnaker to my C30, MkIII with a non-standard rig. It has the standard mast but with a tall rig bowsprit, the luff (43’) and foot (13’) are longer than standard. Does not have a true spinnaker halyard with a swivel block at the mast head but does have 2 jib halyards. Also, the forestay is attached to the most forward point on the mast head which is usually where the spinnaker block attaches so the spinnaker can fly forward of the forestay. Adding aspinnaker block wopuld require modifying the forestay length to move it tothe aft attachment point. Right ?Question: If I had a sail made to the standard dimension, used the spare jib halyard and added a tack point at the standard foot distance (11’) would a cruising spinnaker fly inside of the forestay ?Tnx, Jeff
