Cruising Spinnaker
I added a CS to my 28.5 a couple of years ago. How I set it up is as follows...1.I placed a swiveling block attached to the headstay fitting. There is an extra hole for connecting it.2. I have 2 snatch blocks I place on the slotted toe-rail at either the widest part of the beam or at the aft end of the toe rail.3. My CS came with a sleve that fits around my furled genoa and allows the CS to ride up/down on the genoa.4. My CS came with a downhaul which runs thru the block at the tack and I run it back to the cleat at the stern.This controls the height of the CS.5. I run the sheets outside all of the shrouds, forestay, etc.To use it, I hoist the CS in its sock and run the downhaul back to the cleat. I then raise the sock and trim the sail. I adjust the downhaul so the sail rides about even with the top of the bow pulpit.It really works quite well. Hope this helps.
