Cruising on my H37C.
5,802
Things that have worked really, really well: new Yanmar 3YM30, old Simrad WP30 has steered all the way in all conditions, old Origo stove cooks as well as at home and if it is slower then I can’t tell, crew members Don and Gary are great, Cricket head will flush anything and has for ten years, A/B refer is efficient and keeps everything cold, ten year old Mermaid reverse cycle has kept us warm when tied up(we thought we would need it to cool, not heat):, Garmin 172C is worth more than its weight in gold, and don’t forget the boat. Ladylove is stable, safe, fun, and relatively fast.
Undecided about: davits versus towing; battery charging options when you already motor so much(we have a Honda 2000).
Wish I had: a good boom brake, too many crashes when going downwind in big swells; better cockpit protection when offshore in 30 degrees; the ability to sleep when offshore( I spent three nights in the cockpit ); better tethers for the harness, mine might be dangerous not having a quick release; a dinghy motor that runs, we tore it down while sailing, still will not start(2hp Honda, 4-cycle, air-cooled): a new Passage 42 J .
Sep 25, 2008
77
Macgregor 25 Naples, Fl.
I am enjoying the read, but my finger is getting tired, please post pictures as you go...Sailor's Eye Candy.:dance:
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Neither towing or davits is a good solution when conditions get nasty. Towing is simpler and cheaper, davits reduce drag and improve your fuel economy.
As for boom brakes, I like the Dutchmans... they're pretty easy to install and fairly flexible in terms of adjustment.
Nov 6, 2006
10,217
Outstanding, Ed.. I have been enjoying the "SPOT" log and your write-ups..
G
Guest
Passage 42
Hi Ed, dittos here. We purchased Belle-Vie, a fully loaded 1991 P42, in 2002. Since then she has taken us several thousand cruising miles all in PNW waters. Except for our Garmin 178C chart system and Wallas furnace, most everything else is original. The Autohelm electronics (wind, depth, speed, pilot, etc.) always work, albeit temperamental at times (wind will not wake up at times, especially in cold weather). Its dual Marine Air heat pumps come in handy when connected to shore power. Cold beer handy all the time; had to replace one of the control modules five years ago. Maxwell windlass always works as long as it has power (another story).
All in all no regrets. Perhaps you visited the 42 Hunter Owner Improvements tab above, if not it contains several articles that I've written about our boat. Also, the "Destinations" forum (page 2) has an article that I wrote about our Ocean Falls cruise this past season. The archive should contain stories of our other cruises.
Terry Cox
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Offshore sleeping
Couple years ago I was helping a friend deliver a boat to Houston from Tampa. No sea berth on the boat, and no where to get much needed sleep while underway, without the risk of endin up thrown to the floor... Simple solution when the boat was rolling around some. Throw a sleeping bag in the floor of the boat. You might slide around a little, but no danger of getting thrown out of a berth.
Oct 22, 2008
3,502
Just make sure the contents of the interior are well secured, so nothing falls on you during the night. :D
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I've been enjoying your cruise since you left NC and I see by SPOT your flying up the west coast toward your destination, fair winds and safe passage the rest of the way
Dec 9, 2008
426
1980 Hunter 30 "Denali" Seaford, VA
I too have been enjoying keeping up with you. I certainly appreciate you keeping us all posted as it's a lot of fun to read about. I hope that one day I'll be able to do something similar.
Cheers!
