Cruising Big Bend FL
353
Hunter 37 FL
We plan to cruise the Big Bend FL. Did a search on the forum and didn't see anything about it. If you have cruised this area please comment on places to see/avoid. We intend to provision well since it seems based on research so far there aren't many places to go ashore and grocery shop. We draw 4'2".
Jun 2, 2004
3,653
Been as far East as St Marks
If you are going that way. Find a copy of "Cruising Guide to Florida's Big Bend" written by Captain Rick Rhodes. St Marks was a nice place to stop and spend a couple of days.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
With a 4 foot draft you will be OK in some stops along the Big Bend, BUT a good set of current charts are a must and pay close attention to the tides, which are normally about 2 1/2 feet. Keep in mind that wind conditions can also change the depths rather quickly. The Homossassa River ranges from 4 to 5 feet and has lots of shoals, so might not be a good idea for the first time. The Crystal River should be accessible for you but again, you will need current charts and stay in the channel. There are lots of facilities here and the area is a Manatee preserve. It is one of our favorite stops. A good overnight or rest stop is the uncompleted Florida Barge Canal. Don't go beyond the bridge since there is a power line that hangs down below the bridge that you won't see until you hit it. There is nothing there, but a small boat ramp will get you ashore for some great walking trails, this is a state park, oh and some great fishing. Cedar Key is another must stop for us. Again, critical they you stay in the main channel. The only marina is the City Marina which has no services and is just OK. It can be exposed in southerly winds. You can anchor near the docks. It actually can be pretty exposed and bumpy anyhwere in bad weather. With your draft the Suwannee is too shallow. The Steinhatchee has depths of only about 4 feet and a 25 foot fixed bridge. From there your next stop would be the St. Marks River and then Carrabelle. Keep in mind that this entire area is pretty remote with very limited to no services and facilities. Approaches to almost every river entrance should be done at high tide or on a rising tide. It is a very beautiful area if you can handle the depths and the lack of facilities. Chuck
Oct 11, 2009
98
Lazyjack Schooner Fairhope, AL
We sailed our 39' LOA schooner (draws 2'10") last April from Hudson, just north of Tarpon Springs/Anclote Key, to Apalachicola and then on thru the ICW to Mobile Bay.
Along the entire route you'll find very shallow water (3' or less) extending 2-3 miles from shore, and limited anchorages/marinas, generally spaced 30+ miles apart. To get to what anchorages there are, you'll have to navigate long, narrow channels through the shallows to shore (many of which are themselves so shallow, they cannot be navigated at low tide); and often then motor several miles up rivers to reach your destination - all of which adds a couple of hours on either end of your transit day.
Winds vary depending on time of year. Winters, winds are predominantly out of the north to north-east; summers, south to south-east. The shallows can kick up rapidly.
Our route was: Hudson to Yankeetown (on the Withlahoochee River); Yankeetown to Suwanee; Suwanee to Apalachicola. We by-passed possible overnights at Crystal River, Steinhatchee, Cedar Key, Carabelle and St. Marks. You are correct, at all of these locations there are limited opportunities to provision and fuel. There are small markets within limited walking distance at Hudson and Suwanee, and perhaps at Steinhatchee and Cedar Key.
Of the places we'd visit, the ones we'd return to are Hudson - cute little beach area, several good restaurants; and Suwanee, which was a small "old Florida" town and a beautiful river one could motor quite a ways up. We'd like to go to Cedar Key at some point; we skipped it this time because we were told the channels could be tricky and it's an anchor-only port, somewhat exposed (we had never anchored this boat before and didnt' want this to be the first time).
In between Suwanee/Steinhatchee and Apalachicola is bascially an overnighter given the distances. We considered going Suwanee to Steinhatchee and then across but the time/distance was about the same between each and Apalachicola. Our crossing was 25 hours dock-to-dock and we encountered much rougher winds/waves than predicted (a common problem all along the Gulf Coast).
We loved Apalachicola and highly recommend it as a cruising destination. Lots of old neighborhoods to stroll by, a nice nautical museum, and good shops and restaurants.
Many cruisers by-pass the Big Bend by doing an offshore passage direct from Apalachicola/Carabelle to Cedar Key, and then another to Anclote Key. Some do Apalachicola/Anclote Key direct. That will be our plan next year, when we plan to take the boat to the Keys for a month or so.
I agree that Rick Rhodes' book is a good reference to have on the trip. Make sure you have up-to-date charts for the area; there are quite a few obstructions south of Apalachicola, and there is a missile test range down there that occasionally is declared a prohibited area when missiles are being fired.
This is just an overview; if you'd like, send me a PM and I can provide more detailed info on the marinas we used.
Mike Turner
Lazyjack 32 schooner "Mary'Lis"
Mobile Bay, Alabama
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Fla. Panhandle
I can't give you much advice on the area between Anclote Key and Applalchicola. Too much very shallow water in that area for me to go in there. Tidal currents are strong, and bars build up and go away almost overnight. From Appalachicola going west, I have traveled that section a lot. Mast height is a concern going west from there. You can go from Appalachicola to Port. St. Joe, with a mast height over 50 ft. but from Pt. St. Joe to Pennsacola you have to go offshore if you have 50' or more mast height. Both these are very enjoyable places to visit. I would recommend the Water Street marina in Appalachicola, and they have recently had a deal where by you rent a hotel room and get free boat slip. Be sure to try Pappa Johns for a place to eat, a couple hundred yards down from the Water Street marina. In Port St.Joe, the marina advertises themselves as the friendliest on the gulf coast and is very nice. Provisioning there is easy also.
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
I have been sailing this are for awhile. You really do need to sail with your eyes on the water and look for changes in color. There is shoaling everywhere. Often you have to go 10 miles out to get 20 foot of water. Sand is constantly shifting. Places like Carrabelle can be a little misleading for people that do not know the river entrance. There is a shoal that is well marked and huge on charts. The problem is that there is a green marker to the inside of the shoal, and a green marker to the outside of the shoal as there are two approaches to come in. If you are on the outside and do not realize there are two ways to come in, you could easily think you are in a channel and wind up on the shoal. I love Carrabelle and probably will keep my boat there this summer, but it does seem marked odd. Port St. Joe is rather nice. You can get to several marinas and a state park's dock very easily. Appalachicola is really worth staying for a day or two. We have been there many times and drive down for the Appalachicola seafood festival, awesome event. The whole town is walking distance from the marina and lots of good restaurants that are very affordable. Appalachicola is one of those towns that should be on any sailor's chart, the layout is great for walking from your boat.
