Boat Information for my 30 Catalina
Researching type of CruiseAir. The owner which I bought the boat from said he had never had any problems with it. I believe him, but he was also not an all year sailor and believe he did not use it in the winter and he just upgraded to the CruisAir just this past full calendar year. It uses a 20 amp fuze on accessory. I did many tests on it over the last couple of days and here's what I have find out. If the system is on...it's ok. If it is just running the fan... it's ok. As soon as it starts the compressor to cool or heat... it immediately gets hot and within minutes (pop), nipple comes out from what I believe is overheating (had my finger on the fuze the whole time). All other fuzes appear to work just fine before and after casualty. I even turned everything off in the boat except for the heater and still that didn't work, which I thought would definitely solve the problem. I am running a 30 amp shore cable and believe I will only be able to resolve problem by upgrading to a 50 amp system. I can hear boat electrician cash registers aroud the world $$$. Then increase the fuze capability to something higher than 20 amps and add that refrigerator my wife keeps nagging me about, which is just not possible on 30 amps. What do you think? Am I going the wrong way.
