I can't decide what is best in this case: Re-use my existing OEM important standing rigging part. Or go with the new part that I have bought but from just a visual look doesn't quite match the OEM.
Background is that I read on these forums a couple of years ago about failures of U-Bolts that act as "chain plates" connecting standing rigging wire to the deck or toe rail ... etc. My two 35 year old U-bolts that attach my split backstays to the toe-rail near the stern seemed to fall into the category. One of these is shown in the attached photo. Since Hunter installed them without any isolation between the aluminum toe rail, galavanic corrosion was evident. I was worried about unseen crevice corrosion within the u-bolt metal.
Before removing the 35 year old u-bolts, I ordered a couple of Wichard #6542 replacements that had the same 1 3/8" span between the centers as my existing OEM u-bolts. The strength specs are:
Working load - 2400kg (= 5,291 lbs)
Breaking load - 4800kg (=10,579 lbs)
Upon removing my OEM u-bolts (which as an aside was quite a task due to limited access and my body being too big), I discovered a couple of things:
1) Even though the distance between the centers of the two "arms" are the same 1 3/8", the bolt diameter of the OEM's is larger than the the Wichard's I bought;
2) The OEM's upon removal looked GREAT! No crevice corrosion evident at all. Actually no rust or pitting I can see. 35 years on the boat? Amazing!
Also attached is a photo of the old OEM and the new Wichard side-by-side. All I did to the OEM was soak in acetone for a while to remove the original caulk/sealant. Although the Wichard legs are shorter, still plenty long enough for my application. The amount of thread of the OEM part that Hunter installed was about 2" longer than necessary.
So my conundrum is:
- Now that I know that the OEM u-bolts seems just fine, should I just re-install them? After all, they do have the larger bolt diameter. But I suspect that the OEM's are (say) 316 SS with no "hardening".
- Or do I install the Wichard's that I bought. Even though the bolt diameter is somewhat smaller, I believe that the Wichard's are tempered/hardened and just might have equal or even higher load specs than the OEM's.
My inclination is to install the new ... maybe because I bought them many months ago and now no chance of returning!
So my conundrum is:
