Solo
95% of the time I sail my C320 solo...this year I have been out almost every week and have had crew (in name only) on two occasions. It is very easy, and I actually prefer to sail alone. To answer your questions:- Don't have an auto pilot...don't want or need one. To come about, I move in front of the wheel (after applying some friction to it), slowly turn into the wind, release the lee sheet, move the traveller/main sheet, secure the new lee sheet...all the while controling the rate of turn by reaching around to the wheel. From my position in front of the wheel, I can reach all the lines and the wheel. Most important is to have all lines led aft, therefore, there is no reason to leave the cockpit.- I remain pointed into the wind when raising the main by applying friction to the wheel and keeping enough engine rpm to maintain headway.- Dousing the main (I have a Dutchman flaking system) is normally done by getting out of the wind by getting on the lee side of an island. If that is not possible, I douse it by the reverse method used to raise it.- I sail on a lake that runs north south, with the wind usually out of the south. I do lots of tacking!- If I need to go below for any reason, once again, I friction the wheel...and while below, keep an eye out to be sure I am maintaining a relatively straight course. If not, I go back up and move the wheel accordingly.- When docking...I have a slip with fingers on each side...I come in VERY slowly, cheating a bit to port. To disapate what forward movement is remaining, I put it in reverse, which results in prop walk which pulls the stern to the finger on the port side. I step out and secure my lines...all eight of them.All you can do is get out and play with your boat and try various things...and have fun!
