Has anyone created a bilge sump access panel on a 11.0a? The manufacturer access is actually in front of the sump, seems like it would be better to increase the panel towards the engine for full access. I have installed a remote bilge pump and would like to install a small bilge located in the bottom of the sump for the every so often pumps and use the larger remote pump as a backup, float would be higher then the small pump.
Patrick
Patrick
