Cranking battery ground cable replacement for 1gm
Nov 1, 2012
108
IM having intermittent starting issues. From all I can gather it's a bad ground. I'm sure the cable is original.
My question: have any of you changed the grounding cable before? Mine is attached to the aft, starboard engine mount bolt. I don't want to create an alignment problem trying to fix a grounding problem.
Are any of your 1gm's grounded to a more convenient location?
I posted in propulsion, but got no response.
Thanks
Joe
Nov 22, 2011
1,303
Ericson 26-2 San Pedro, CA
Thanks
Joe
Mine was originally installed on an engine mount bolt as well. When I re-did the wiring to the engine I ran the ground wire to one of the starter motor bolts.
Jun 3, 2004
269
Oday and Catalina O'Day 25 and Catalina 30 Milwaukee
Joe -
What are the symptoms? Just curious.
Dave
s/v Lagniappe
O'Day 25
Nov 1, 2012
108
Intermittent low power when I push starter button. Usually I get a click noise. I let off the button and try again and it cranks great. Usually worse after sitting for a couple of weeks. When I sail a lot it never happens.
Jun 3, 2004
269
Joe -
FYI, I had that problem and it was the solenoid. Had the starter rebuilt and it fixed that problem.
Dave
s/v Lagniappe
O'Day 25
