Hunter 31 cradle measurements
Hi,
I went down to the cradle and took some measurements. The Base is made out of 4” by 1 5/8” C beams. It measures 63 ½” wide by 12’ long.
66“ between stern tube and mid post. Stern tubes and mid tubes are vertical. Stern tubes and mid tubes are 26 ¾” tall.
74 ½” between mid tubes and bow tubes at top of both tubes. 76” between mid tubes and bow tubes at bottom of both tubes. This is because the bow tubes are slightly angled into the cradle 10-15 degrees.
50” between bow tubes at top. Bow insert posts are 35” high.
All pads are 16 ½” square with foam pads
Diagonal braces attached to base 22” from base of tubes. 1 brace on each stern tube, 3 braces on mid tubes, 2 braces on bow tubes
Insert posts in tubes 6”.
Keel tray 9 ½” wide and 78” long, 32” from bow, 33 3/4” from stern.
Grids 22” square on inside
Let me know if you have and questions.
Rip
