IF ANYONE HAS DIMENSIONS FOR A CRADLE FOR THE 272 IT WOULD HELP AS I AM GOING TO BUILD ONE TO MOUNT ON A FLAT TRAILER TO TRANSPORT MY BOAT AND TO DRY STORE. IT IS PRESENTLY IN A WET SLIP
Dennis,Hopefully Thomas is nearby. If you get really stuck post again and I will give a call to a couple of trailer sailor that support with pads and not bunks.r.w.landau
I having a cradle built for my O'Day 28 for the same use. Check JOWI Sailboat Cradles @ www.jowi.com they will give you measurements. I also purchased screw up support pads from JDWI Sailboat Support Systems. The spec call for only four pads; however, I used six inorder to be able to drop a pad to work on the boat. The total cost of the cradle will be about $450.00.Good luck
