BTW Lexan can & will crack. We used to have an O'Day 35 will large aft Lexan glass fixed ports. They cracked along the screw holes made to secure the perimeter of the ports. We replaced them with official Lexan poly, & low & behold they indeed cracked again within about 2 years later. Very frustrating. Also had an S 2 with smoked Lexan ports that cracked at the corners. Didn't bother replacing them.
We just used a very thin bead of clear 100 % silicone caulking & it worked great to repair the crack for years. It also stays fairly flexible & didn't dry out & leak after several years. The clear silicone is almost invisible, & doesn't make a messy repair. We applied the thin bead inside & outside of the crack for better coverage. Knowing now how easy it is to potential stress crack Plexiglass & Lexan, I would never drill it in the future.
