I have a Beneteau Oceanis 311 which has developed a crack in the salon floor running across below the galley sink. This had occurred while the boat has been out of the water in a cradle during the winter. While the survey done hast year said the hull etc. was sound, This area showed some reinforcing; namely a layer of Grp mat, it is this that has failed.(Epoxy/ polyester??) I would now assume that some damage had occurred previously, but I don't know for sure.
The hull appears to be unaffected on a visual inspection, (but is covered by anti-fouling at the moment.)
The crack widens to about 10 mm max in the middle.
The door under the sink sticks and the island unit may be warped.
Has anyone had a similar problem?
Would it be safe to launch and see if the crack closes before attempting a repair. The boat is not at a marina so is floated off the cradle and would take a little time to get back out again.
Any advice welcome.
Any advice welcome.
