Hi all,
Last weekend we unstepped the mast from our 1984 Beneteau First 38. Upon inspection of the mast at grade level we noted that the front part of the masthead aluminum casting was cracked. The crack is on the portion of the masthead to which the headstay is connected. The stemball fitting (which is located in the cast aluminum fitting & is free to articulate) has a toggle at the end of the stemball fitting to which the headsail furler is attached. There is a slight chance that the area where the crack is does not support any loads.
Questions…..
Has anyone else experienced this problem? Can this crack be TIG or MIG welded? Or do I need to replace the front section of the mast head. Any other suggestions?
I will be contacting Rig-Rite Inc, 63 Centerville Rd Warwick, RI (www.rigrite.com) and also SPARCRAFT - US (Charleston Spar), 3901 Pine Grove Circle, Charlotte, NC (www.sparcraft-us.com) looking for advice and replacement parts. The masthead is welded to the mast and the weld will need to be ground out to install a new piece – if available.
Mast still had the original manufacturer logo and serial number label. Serial number is “62906”. Per SPARCRAFT website they have access to the original “as built” files from ISOMAT & KENYON. We shall see.
Mast: ISOMAT NG 60 <- confirmed by measurements & Beneteau brochure
Masthead: ISOMAT NGII <- confirmed from dated ISOMAT catalogue
Doug in Lakeview
1984 Beneteau First 38 – Hull #178
Belmont Harbor – Chicago
Questions…..
Doug in Lakeview
