Bruce,I have a crack in my Hunter 27 aft of my keel, from flexing, that is about 3" long through all laminates, starting at the keel. Additionaly, the stiffener above is cracked. My plan was to drop the keel, cut out the sole for access and grind away. I assume the Catalina smile procedure posted earlier would finish up the job, and wonder how much I need to remove around the crack. (It would be great if you told me I didn't have to drop the keel). Also what is the best method to repair a cracked stiffener?Thanks RandyHunter 27
