Key is a healthy electrical system with a reliable energy budget and a big house bank, 400 ah. Min.Key to success is insulation.
I have. 1986 P36-2 that was upgraded to include a cold plate. Great upgrade. If you would like I can send you photos of the install and where compressor and plate are located.Ahoy mateys,
I just purchased a 1988 Pearson 36-2. It still has the original built in icebox. I dread tearing it out and replacing so was wondering if I could somehow install a coldplate in the original, or is it even worth it.
Thanks.
Thanks NYSail, I would love those pics and also what brand of CP if known. Not sure if I should post my email or if there is another way to get it to you. Also, I have 4 grp 27 house batteries.I have. 1986 P36-2 that was upgraded to include a cold plate. Great upgrade. If you would like I can send you photos of the install and where compressor and plate are located.
I will snap some pictures and send you all information on the CP I have.... Its an Adler Barbour. You can send me a message on this site with your emailThanks NYSail, I would love those pics and also what brand of CP if known. Not sure if I should post my email or if there is another way to get it to you. Also, I have 4 grp 27 house batteries.
I installed that type of unit in my last boat. Worked very very poorly. In my opinion it was a waste of time money and effort. As I remember it was an energy hog for the amount of cooling. I ended up taking it out and installing an Isotherm Holding Plate ASU system(purchased from Defender).I am going to install a double Peltier unit in my 272 icebox.
Interesting! Thanks for the info. Do you daysail or cruise? I had some worry about the energy consumption, but my experience with my cooler has been excellent, so far. The cost is only $25.00 for the Peltier unit, so the cost is really not a waste to find out for me. My icebox is better insulated and about the same size as my cooler. Considering we only spend a day or so a week on the boat, and we have used our electric cooler on the boat while day sailing, I am not worried about power. We have left our electric cooler running while sailing for 4 hours, and it did not drain our batteries. We are back at the dock every night. I will certainly look at this Isotherm ASU unit!I installed that type of unit in my last boat. Worked very very poorly. In my opinion it was a waste of time money and effort. As I remember it was an energy hog for the amount of cooling. I ended up taking it out and installing an Isotherm Holding Plate ASU system(purchased from Defender).
An excellent unit both in ease of installation and extremely low energy consumption, much better than any evaporative system. If the evaporative system in my current boat ever quits I will not hesitate to install an other Isotherm ASU holding Plate again.
I would like to leave so stuff on the boat too. We have always returned to the dock so far, since we are on a lake. I think the temp differential for the Peltier is like 45 degrees, but I routinely find ice in the bottom of my cooler after it has run for the weekend. We used to turn it off while sailing, and it kept the food cold. Once we tried running it while sailing, we found it did not drain the batteries too much. If I was going to anchor overnight, I would not leave it on unless I had some solar or wind generation. It will be an interesting, low risk, low cost experiment. If we don't like it, we can do the cold plate.Mostly day sail but I almost leave the refrigeration on, as I don't want packing up the boat to go sailing to be a project. We like to walk down to the boat and go. So stuff is left in the refrigerator all the time.
Keep in mind a Peltier can only only cool to a certain number of degrees (can't remember how many) below ambient air temperature so if you are in a hot climate don't expect really cold stuff
