Cost to Refinish 60' Aluminum Mast
Jan 14, 2014
3
Endeavor 32 St. Marys, Ga
Hi, Could use a little help from some of you more experienced sailors.
I recently purchased a 32' Endeavor. I would like to get the mast and boom refinished. The mast is about 60' and the boom is 14'. All the hardware and rigging looks good, just need to get the mast and boom refinished. Anyone had this done before or know the cost for labor to strip and apply Awlgrip? Any help would be greatly appreciated.......
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
Find a rigger company in your area and get a quote!
Jan 14, 2014
3
Just trying to get a ballpark figure so I know that the price is fair. I did get a quote for $1800 labor only. This doesn't include removing or reinstalling the mast though. Does this price seem fair, or should I look elsewhere?
Seems cheap to me. Cheap enough so that I might wonder if they can do it to a high standard for that price. As I understand it Awlgrip isn't easy to prep for overcoating, which might mean removal - i.e. a lot of expensive labor. But, I'm not in that business and others on this forum are so I would defer to them.
Sorry, misread OP. The mast has not previously been painted.
I did my Ranger 29 mast with Interlux one part epoxy and the Rx'ed primers in my backyard one winter. Results were very satisfactory to me. But it was lots of hours of prep, painting, turning over, re-prep, repeat until done. A lot of labor still. $1,800 still doesn't sound that high for a quality job.
6,243
S2 9.2a Fairhope Al
if you can get it to North Carolina you can have it refinished by Charleston spars and it may not be that high ...heres the but ...getting it there and back is going to be the deal breaker unless you are very resourceful....
regards
woody
Hunter 37 C sloop Punta Gorda FL
Hi, Could use a little help from some of you more experienced sailors. I recently purchased a 32' Endeavor. I would like to get the mast and boom refinished. The mast is about 60' and the boom is 14'. All the hardware and rigging looks good, just need to get the mast and boom refinished. Anyone had this done before or know the cost for labor to strip and apply Awlgrip? Any help would be greatly appreciated.......
Easy enuff to do yourself. You need to be extra fussy in prep and priming,as not much adheres well to aluminum except aluminum primer .
Jan 14, 2014
3
Thanks for all the great advice guys. I may just try it myself. Can I use a caustic stripper like Klean Strip and not damage the aluminum to remove the existing paint, and finish up with sandpaper on a DA? Also, can I etch it with some type of acid, or use a self etching primer? Again, thanks for all the input.
caguy
Sep 22, 2006
4,004
There was a detailed thread of one of the members who painted his in the basement a few year's ago. It turned out beautifully, I searched but could not find the thread.
Joe
Jun 1, 2004
8,175
Here's a short article on prepping the mast for paint.....http://www.ehow.com/how_7765048_paint-aluminum-sailboat-masts.html
You can use a one part epoxy paint such as Interlux Brightside.... but I have seen fantastic results with the 2 part such a Interlux perfection. Whatever paint you decide to use, follow manufacturers' instructions for primers, cleaners and thinning agents.http://www.yachtpaint.com/LiteratureCentre/perfection-bulletin-usa-eng.pdf
It's not realy that hard...once you get the roll and tip method sorted out and understand how temperature affects dry time. Your biggest challenge will be dropping the mast and locating it in a proper work space.http://www.jamestowndistributors.com/userportal/show_product.do?pid=1439
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i think that was by TimR.....
regards
woody
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Brightside and Easypoxy are both 1 part polyurethane paints.
The durability of a 2 part polyurethane is FAR superior to the 1 part paints.
