Cost of installing forced air heat
Patricia
We are in the process of buying a used Catalina 1987+. We were wondering how much it would cost to install forced air heat? Is this standard on any of the models? Thanks for your help.
L
LaDonna Bubak - Planet Catalina
Forced air
Forced air is definitely the way to go but the cost is pretty high. I think it's in the $2-3000 range (from what I've heard). If you're mechanically inclined you can buy the system & install it yourself but I'll bet the warranties wouldn't apply then. Good luck & stay warm! LaDonna
John Mavrovich
12,000 BTUs
I installed a 12,000 BTU reverse cycle air conditioner in early spring. I mounted the unit in the port side cockpit locker. With three air outlets (v berth, head, galley) it heats and cools adequately - even this summer in North Carolina's high temperatures. The system I used is Mermaid. They're in Florida and have mail order dealers that sell it for less than you can buy it directly. I paid just under $1400 and did the job myself in 2 days. Good luck.
