Cost of a New Yanmar 44HP Installed?
I asked how many hours were on the engine but the owner did not know....apparently there is no instrument counting the hours?? Found that kinda odd....is that fairly normal?
On older boats, not unusual. Later models often have them. When my boat was 7 years old, a prior owner installed one. They are not expensive and fairly easy to install, might be something to consider if you should purchase a boat without an hour meter.
Ask how much fuel the owner buys each year and how large a fuel tank he has. At cruising speed, he probably burns around .75 quarts per hour. From that you can get a rough estimate of the hours.
Likes: GeneraiT001
Greg you can approximate the time by discussing with the seller about where and how he sailed he’s boat.
For example getting in and out of a marina can take 60-90 minutes per sailing event. On average it has been estimated that most boats spend most of their time each year tied to the marina slip.
Most boat owners will share enough information about their experiences to estimate the hours.
More important is what does the engine look like? How does it sounds? How does the engine propel the boat through the water?
Likes: GeneraiT001
Jun 17, 2022
348
Hunter 380 Comox BC
HI,
First post :)
I'm about to look at my first sailboat (to buy) in a couple of days. I have zero sailing experience. Its a Bayfield 36 and was curious what a ballpark price would be should it need a new engine - Yanmar 44HP? I'm guessing in the $10,000 - $15,000 CDN range (installed)?
Thanks
Welcome! We haven't heard back so assuming you've walked away?
If you are making an offer, make sure it's subject to a sea trial. A boat that's been sitting on the hard for a few years can be indicative of very serious issues.
40-45 HP sounds about right for that displacement. For the total cost of a new engine installed, take the cost of the engine itself and double it to cover off installation cost and accessories. Modifications may be required to engine beds, exhaust routing, etc... You'll want new fuel lines, exhaust lines, maybe a new water lock .... So if a Beta 38 or 44 is $19 000 (I'm guessing), then you're likely looking into the $40 000 range plus taxes once it's all said and done. Going with a Yanmar would likely add $6000-$10 000 to the cost.
Any reason you are looking at a long keel? They are not beginner friendly to dock.... they tend to be slow in light air as well.
Given the cost of a new boat, insurance, a slip and all the "surprises" that will cost many boat units ($1000) in the first year, I would suggest it would be in your best interest to learn to sail first, then charter to see what you like don't like. Most areas have keelboat racing leagues that are always looking for crew. This is a great way to learn and meet boaters.
