Corrosion
Canoe
Dec 25, 2008
11
Hunter 336 Everett, WA
Let me ask a question about corrosion. I'm seeing corrosion on the motor mounts on my yanmar 3gm. My motor mounts are electrically isolated from the motor and boat neutral/ground. Should there be a bonding strap from the mount to the motor
Canoe
Sep 25, 2008
7,751
Alden 50 Sarasota, Florida
It makes no difference since the mount bases are isolated from ground, I.e., there is no circuit to complete or interrupt
Oct 29, 2005
2,366
Corrosion is probably due to seawater from raw water pump splashing on it.
Jul 24, 2012
53
Hunter H31 Saint John NB CA
I am also seeing heavy rust flaking on my motor mounts on my 1986 H31 yanmar
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
my mounts started to get rusty because I had a cracked aft side of the mixing elbow and couldn't see the crack until I pulled & replaced the entire exhaust column/mixing elbow.
