Let me ask a question about corrosion. I'm seeing corrosion on the motor mounts on my yanmar 3gm. My motor mounts are electrically isolated from the motor and boat neutral/ground. Should there be a bonding strap from the mount to the motor
Canoe
my mounts started to get rusty because I had a cracked aft side of the mixing elbow and couldn't see the crack until I pulled & replaced the entire exhaust column/mixing elbow.
