Corrosion on keel bolts
Aug 15, 2013
193
Hunter 35.5 Legend 003 San Carlos, Sonora, Mexico
I would like to know if anyone has experience removing their keel bolt hardware. Unfortunately (in my opinion) Hunter used plain steel washers under the stainless steel nuts and bolts for their keel fasteners. I believe their thinking was to alert you to corrosion, sounds like a weak idea. In a bilge that get shower water drain (and seawater) therefore never dry, this will cause corrosion. My washers are all rust. I tried removing them, but my 300 Lbs behind the breaker bar was not enough. I was considering spraying with PB Blaster but wondered if that might not be a good idea. I am concerned about crevice corrosion now that the washers have swollen and possibly blocked off any oxygen the bolts need to maintain their integrity.
Primarily theses are the bolts where the bilge pump lives. I have created a plastic box/shower sump drain so the bilge is now dry (used your idea ElMax - excellent), causing even more concern over the aggressive corrosion.
I would like to clean and dry the bolts and replace the washers with 314 SS washers (not cheap... $7-10 ea - no wonder they didn't use SS) and put some corrosion prevention down or maybe even a little "coffer-dam" around the bolts to keep them dry.
Anybody have to do this? What were your results? Any suggestions for the task? Will the PB Blaster cause problems if it gets down to the keel bolt/keel interface?
Thanks.
Likes: ELMAX
ELMAX
Jan 23, 2013
119
Hunter 35.5 Greece
Not easy ... and the place to work and narrow, I have built a key to doing this by combining a longer bar. A photo would help to understand the situation ...:doh:
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I think a long soak in pb blaster will help. Then try a 3/4" drive 4:1 torque multiplier between the socket and the bar. You might be able to borrow or rent it from a heavy truck/machinery mechanic. Harbour Freight may sell them. I bought one from Princess Auto here in Canada.
Good luck, Bob
JamesG161
Feb 14, 2014
7,934
Hunter 430 Waveland, MS
An easier way is to put a zinc in you bilge water, connect the bolts electrically, maybe a stainless hose clamp with spade wire hook up.
wahhh lahhhh no more galvanic loss. You can easlily change the zinc. My guess, 8oz zinc will last a couple of years.
Jim...
ELMAX
Jan 23, 2013
119
Hunter 35.5 Greece
I put one zinc, if it enters water in the bilge. I made sure the bilge is always dry.IMG_0063.JPGIMG_2376.jpgIMG_4747.jpg
Aug 15, 2013
193
ElMax, I think you have the best looking bilge I have ever seen.....
Likes: Franklin
JDemo
Apr 1, 2016
12
Hunter 42cc Alameda, Ca
Where did you go to find the backing plates and nuts? I would like to clean up my Passage 42 CC. Backing plates look very rusted. I thought the plates were mild steel? Only fresh water in the bilge. Mostly from refer/freezer condensation.
ELMAX
Jan 23, 2013
119
Hunter 35.5 Greece
I have not replaced them, I took them, cleaned, put back, I used to clean the drill with a bronze brush. Hello
JDemo
Apr 1, 2016
12
Thanks, mine are beyond saving. I can clean up the nuts, but I will have to replace the washers. My bolts stand side by side in pairs fairly close together. That's why I thought there was a specific part from Hunter. A regular round washer will need to be ground flat on one side to not interfere with the neighboring bolt.
Thanks
Grazie mille
Likes: ELMAX
Sep 8, 2014
2,551
You can get 316 ss washers from Fastenal online. Not cheap, about $8 each.
Steve, try McMaster-Carr to get 316 Stainless washers. I love Fastenal for many things but they mark up everything to the max. McMaster Carr isn't always the cheapest for everything either, but the site is much easier to navigate. When you do a search and you can set specifics by size & length of faster, but more importantly in this case you can limit search results to washers made of 316 stainless. See link below, washers in 1 inch ID of 316 SS can be had for $4 ea. Their international shipping could be more reliable than Fastenal (maybe).
http://www.mcmaster.com/#standard-washers/=11tnlru
If you ever come up to the mainland let me know, I could cut you some bilge plates from stainless sheet with my plasma cutter, you would have to bring templates made of stiff cardboard or plywood so I can cut it right the first time.
Likes: ELMAX
JDemo
Apr 1, 2016
12
I wanted to do it in the water, but was advised by a local tech that proper torquing was only done with weight on the keel.
What is your opinion ?
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
That is what I have would have done, (out of the water with some weight on the keel). I just couldn't tell from the above discussion.
Thanks,
Jeff
Aug 15, 2013
193
When I do it, it will be out of the water, resting on the keel and stands
