I'm fixin' to purchase a SCAD Solo holding tank monitoring system from Sailor Solutions. I'm ordering the internal probe because (dangit) my tank is 5052 AL. I need to drill for the hole. SCAD recommends their aluminum adapter plate to easily mount the probe. (see link to dwg). Before I pull the trigger, my question/concern is the right way to fasten the plate to the tank for security and to avoid corrosion. Should I use AL rivets? Won't SS bolts cause galvanic corrosion? Is there a better way to fasten the plate?
http://www.scadtech.com/sites/default/files/adaptorPlate.pdf
